Cleaning out my garage! ECU's, ITR parts, lots and lots of misc. mounts/brackets/parts
LOCATED IN AND AROUND THE SO. CAL. LONG BEACH AREA. Everything is sold as-is. I will do my best to update this thread with new stuff as i find them. I dont have pictures for everything as that would take forever to do. I can be as descriptive as possible in regards to condition if you want something that you dont see.
1997 ITR JDM parts with 17,xxx kilometers:
- Timing belt.
- Water pump.
- Both radiator fans.
- Power steering pump w/reservoir.
- Alternator.
- Halfshaft, aka intermediate shaft.
- Driver side axle.
- Complete oem oil cooler set up with water pipe, all fittings/hoses.
- S80 outer trans case half (the side the trans mount bolts to).
OBD-0/1 SOHC parts
- 88-91 civic/crx Si/DX upper half of exhaust manifold. $10
EF/DA stuff that i found at the moment.
- AEM crx/hatchback Si cold air intake. Silver. Original K&N filter is literally like new, low low miles. $ ?
- USDM EF hatchback rear hatch with glass, shaved wiper and H badge holes, no wing, painted factory polar white. $40
- 2 EF Si PM6 ECU (year '90 and '89). $40 FIRM/each
- 1 EF DOHC ZC PM7 ECU. $?
- 1 EF Si PM6 MAP/purge assemblies (mounts to the firewall). $10
- 2 EF charcoal canister. $10 each
- 1 DA 90-91 LS tranny complete but has Y1 5th gear, could have a trans issue, cant remember, you buy it for cheap and find out/fix it. $?
DOHC first gen B16 related parts: Some things arent pictured.
- 2 intake manifolds. $15
- 2 throttle bodies with TPS. $40
- 2 fuel rails. $10
Odds and ends:
- TPS sensors. $?
- EG sohc torque mount brackets (a/c and trans brackets). $?
- PR4 ecu, LS/RS/GS, 90-91, obd-0. $30
- B series halfshaft, came from a 97 del sol vtec b16. $40
- B series clutch slave cylinder with rubber flex hose. $15
- B series 92+ oem honda clutch disc. Used but 75% life left. $20
- B series hydro outer half of trans case (came from a jdm 97 type R). $30
- B series vtec valve covers (2 left). $30
- B series flywheel, recently resurfaced. $30
- B series VTEC rocker arms. 95% complete set, missing 1 middle rocker arm. $?
- B series rear main seal housing. $10
- Exedy clutch disc for 92+ hydro B series. Plenty of life left. $40
- B16A2 crankshaft. MINT/absolutely like new! $?
- B16A2 oem flywheel and oem pressure plate (matched, from a '00 SI). $?
- VAFC I with blue screen, mounting bracket and lots of wire left. $?
- JDM B20 throttle body w/ TPS and MAP sensor. $40
- IAT sensors and IACV's. $?
- EG charcoal canister. $10
- B&M and stock fpr's. $?
- B series cable tranny throw out bearing fork and arm. $?
