Go Back   Honda-Tech > Honda-Tech Marketplace > Classifieds: Forced Induction
Old 05-18-2008, 09:21 PM   #1
2 0 3
2 0 3's Avatar
Send a message via AIM to 2 0 3
Default Parting out PW/S T/S SFWD Race Car!!!
Rolling chassis - sold
SOLD
(for more cage and fab pics see this thread http://www.honda-tech.com/zerothread?id=2238643)
Bogart Fly Stars 4x100 13x8 5" backspacing with MT 24.5 slicks. Slicks have 7 passes on them.
SOLD
Bogart Fly star skinny's 4x100 15x3.5 with MH tires. tires are the old style MH that are not DOT. They don't have much use, but are old and starting to dry rot. We used them no problem, but i would recommend them to be replaced.
SOLD
Bogart Fly stars 4x100 15x9 4.5" backspacing BRAND NEW! Never ran these wheels, mounted some DOT MH's and mounted on the car, but never made a pass with them. One wheel slightly damaged on the inside from when we mounted it with out a spacer and brake calipers scrapped inside Other wheel is brand new mint condition. Paid 660 direct from Bogart less than a month ago. NO TIRES! Will leave tires on if wanted for extra $
$500
M&H DOT cheater slicks 26x10.5 Brand new! Only mounted on wheels, and driven in/out of the trailer. No passes or burnouts ever made on them. Still see John's "Good Luck" writing.
$300
Hoosier Quick Time Pro's 26x9.5 Dot Bias Plys. Made 4 passes on these tires.
SOLD
CF hood w/ Aerolatch hood pin setup
Hood has 2 minor cracks, can honestly barely see them, very difficult for me to even get in a picture. The underside has been cut up a little, for each hood latch and also for clearance with radiator. Good shape otherwise! Super clean looking hood pins! This is a great deal, everyone knows the pins are expensive!
SOLD
Omni Drag suspension for EG/DC full coil-over. Used for 10 passes and a few street miles
SOLD
Full Race traction bars EG/DC used for 10 passes and a few street miles
SOLD
4" Aluminum exhaust for EG. Tig welded by 666fab. Vband flange to turbo DP and VBand to Vibrant 4"x9" race muffler, with turndown. Exhaust fits perfect! no rubbing! Bolt on exhaust.
no scrapes or dents. mint condition!
SOLD
Sumped EG gas tank. Custom 666fab sump, low profile, wide body sump w/ dual -8 male AN's
Tank is brand new, bought it new, sumped it, has only been on the car for 1 dyno session and 4 passes. (don't know the actual measurements of the size of sump, will measure tomorrow)
SOLD
Duel Bosch 044 pump complete fuel system. Lines, fittings, pumps, filters, and mount.
Bolt on 800+HP fuel setup. 2 -8 prolite feed lines, mallory FI filters, 2 bosch 044 pumps, 2 -8 steel braided lines, Magnafuel -8 to -10 Y distribution block, (2) -10 AN to Flare fittings 12ft of Moroso Alum 5/8th hard line, Aeromotive fuel filter, -8 steel line to rail, -6 return line, -6 banjo fitting back into tank. (spent over 1k piecing this all together)
SOLD
ERL big bore Fuel Rail
-8 in/out will come with male to male fittings
bolts to factory location
SOLD
Aeromotive fuel sample valve
works perfect
$60
JG/Edlebrock Victor X intake manifold (GSR) / 74mm RPM Services TB Combo
Manifold was machine bored to 74mm to match the TB
TB has Vband flange welded on, can be removed if you want to use coupler.
TB will come with an OEM TPS sendor, already calibrated & Map sensor
Both in great shape, used for only 15 passes
*Dont want to part since they are port matched
SOLD
2 Sparco "Speed" matching seats
$250 each
(see pictures above)
1 Sparco slider/seat mount for d/s EG/DC
PRICE DROP FREE WITH SEATS
Moroso poly/sealed NHRA approved Battery Box
$75
NRG-Tech catch can, lines, fittings, and valve cover. Complete ventalation set-up
SOLD
Stroud super-comp Parachute. Never used, only bolted on, never pulled!
SOLD
M&W Pro10 Ignition box, Crane PS9 Coil, T1 electrical harness
drop in wire a few wires and go!
SOLD
Competition Clutch Twin disk clutch. B hydro. Used for 15 passes and 3 dyno sessions
Driven on the street for under 100 miles. Great condition, grabs perfect, disks have plenty of life left.
SOLD
G-force Cam lock 5pt harness (purchased end of last season) Used
SOLD
Moroso 5qt trap door oil pan, comes with pick-up of your choice GSR or LS
SOLD
ATI Super Damper street Version, Used 15 passes and 3 dyno sessions
SOLD
DSS 5.9 Axle/hub system for Bseries EG/DC w/ GSR spindles, dss big hubs, and extended studs
brand new wheel bearings. swap the whole setup in an hour, no need for new bearings and a press. sold w or w/o stock intermediate shaft. Big boy axles!!! 1000HP
SOLD
Precision 1000cc Injectors, used for 15 passes, 3 dyno sessions
perfect condition
SOLD
CO2 Kit for boost control, 2.5lb bottle, regulator, gauges, mount, quick disconnect fittings(metal, not cheap plastic ones) line. will include 6 90* fittings, 2 T fittings,1 1-2fitting, 1 straigt fitting, various lengths of line, one long feed line. Setup for dual wastegate setup, and Electronic boost control solenoid.
SOLD
PWR EG Radiator
SOLD
Deist Trans blanket
SOLD
NHRA legal Catch pans. 2" lips, covers from rad suport to firewall, cutouts for control arms to keep catch pans up high, mount to engine and trans, built for an EG/DC with full race bars
Very stout, very by the NHRA rule book! Get compliments from tech every time we race =P
SOLD
G-force SFI Jacket, purchsed late last season, mint
SOLD
G-force M2005 Helmet, few scratches
SOLD
GT4088R Ball bearing Turbo. Used for 3 dyno sessions and 15 passes.
comes with your choice of backhousing .96 or 1.06 (slight price diff, can discuss in pm before final sale) comes with restrictor
Buyer gets free T4 Turbo blanket heat sheild
SOLD
666 Fabrication T4 Top Mount Divided Manifold / DP / Dump tube combo!!
equal length, paired cylinders, manifold is tapped at #3cyl for EGT gauge, twin 44mm waste gate flanges, 4" downpipe w/ heatwrap 3 o2 bungs, one in factory location, two up front for widebande use. 3" vband to turbo, 4" vband to exhaust
Great ground clearence, will come with 2 dump tubes
SOLD
Precision 750IC, perfect condition, no bent fins, no leaks!
SOLD
2 Tial 44mm wastegates, silver, come with small red 4psi springs inside, and large red 10psi springs on the side, you choose which you want to use, or both for 14psi
gates a little scratched up, but work perfect, come with clamps
SOLD
Tial 50mm BOV in silver 11psi
SOLD
3" Aluminum IC piping, couplers, and clamps, vband at TB and Turbo
SOLD
Oil feed line -3 steel braided
Oil Return line -10 steel braided w/ heat sheild
$50
Innovative B EG/DC Billet black mount kit
Good condition!
black inserts on engine side and trans side mounts (forgot what rating)
Solid Nylon insert in rear mount. (some scratches from when machine shop installed insert, no visible behind engine) Motor did not move, and was alot lesh harsh then full solid metal mount kit.
SOLD
Mr. Gasket 10" Electric Fan
Used for 1 dyno session and 1 race, cooled engine down a bit more than the spal
s-blade we had on it last year. I really like this fan! Dont have any pics yet, here is a link to it on jegs http://www.jegs.com/p/Mr.+Gask...10117
$50
3 Autometer Gauges, in custom Pod, fits in heater control spot
All gauges phantom series, Electronic oil pressure, Electronic water temp, Mechanical Boost 60psi. Used for 1 dyno session and 1 race, Pod has is angled towards driver
SOLD
Skunk2 Short shifter and Shift knob combo
mint condition, slightly used
$100
1.05 T4 divided back housing from our 4088R
used for 4 passes, will have a fresh sandblast done before shipping
$ Best offer
Toda Cam Gears, new bolts and washers
SOLD
ITR Cams, dont know what year, can measure
SOLD
Toda Spec B All motor cams, used 2 seasons ago, been sitting since, will clean up nice before sale
SOLD
Eagle Big Bolt Rods, Used for 1 400hp dyno session and some street miles
SOLD
PLX M300 Wideband. Great condition
Sensor, wirring, display, ect ect. Replaced the sensor 4 weeks ago.
PRICE DROP $200
CLICK PICS FOR BIGGER!!!
*More parts to be listed later!
inkage, plx, ect ect CHECK BACK!!!!
Modified by 2 0 3 at 12:58 PM 5/21/2008
Modified by 2 0 3 at 2:04 AM 5/22/2008
Modified by 2 0 3 at 12:08 PM 5/22/2008
Modified by 2 0 3 at 8:17 PM 5/22/2008
Modified by 2 0 3 at 7:51 AM 5/27/2008
Modified by 2 0 3 at 11:40 PM 5/27/2008
Modified by 2 0 3 at 12:28 AM 5/29/2008
Modified by 2 0 3 at 1:43 AM 5/29/2008
Modified by 2 0 3 at 9:24 PM 6/3/2008
Modified by 2 0 3 at 7:46 AM 6/5/2008
Modified by 2 0 3 at 7:47 AM 6/6/2008
Modified by 2 0 3 at 1:10 AM 6/7/2008
Modified by 2 0 3 at 1:12 AM 6/7/2008
Modified by 2 0 3 at 4:20 PM 6/9/2008
Modified by 2 0 3 at 8:10 AM 6/10/2008
Modified by 2 0 3 at 6:51 PM 6/12/2008
Modified by 2 0 3 at 1:16 PM 6/21/2008
Modified by 2 0 3 at 7:48 AM 7/3/2008
Modified by 2 0 3 at 10:06 AM 7/10/2008
Modified by 2 0 3 at 8:48 AM 7/16/2008
Out of the honda game.
yet this is still my homepage haha
2 0 3 is offline   Reply With Quote
Old 05-18-2008, 11:41 PM   #2
ivt-t
1993 Honda Civic
ivt-t's Avatar
Send a message via ICQ to ivt-t Send a message via AIM to ivt-t Send a message via MSN to ivt-t Send a message via Skype™ to ivt-t
Default Re: Parting out PW/S T/S SFWD Race Car!!! (2 0 3)
hi!
i would take the fuel setup,the parachute with mount kit,aluminum exhaust system,trans blanket,if you give me some discount
lmk please
10.08@152mph on street....not prepped lane or anything
fastest street car in Hungary ever
and the first fwd in the 9...
ivt-t is offline   Reply With Quote
Old 05-19-2008, 04:52 AM   #3
2 0 3
2 0 3's Avatar
Default Re: Parting out PW/S T/S SFWD Race Car!!! (ivt-t)
check pm
Old 05-19-2008, 06:23 AM   #4
2 0 3
2 0 3's Avatar
Old 05-19-2008, 09:18 AM   #5
2 0 3
2 0 3's Avatar
Lunch time!
Adding more stuff while i eat
Old 05-19-2008, 09:30 AM   #6
DIS-1
DIS-1's Avatar
Good Stuff
KhAn ShOp!!!
Jerry Built!!!
DIS-1 is offline   Reply With Quote
Old 05-19-2008, 10:10 AM   #7
94delslo
94delslo's Avatar
Default Re: Parting out PW/S T/S SFWD Race Car!!! (DIS-1)
pm'ed about the injectors
JRSC'd JDM b18c Del Sol <--Totaled
SC61 Powered GSR Hatch <--Current Project http://images.honda-tech.com/set1/smile/emthup.gif
94delslo is offline   Reply With Quote
Old 05-19-2008, 11:33 AM   #8
2 0 3
2 0 3's Avatar
Default Re: Parting out PW/S T/S SFWD Race Car!!! (94delslo)
1000cc injectors sold
helmet sold
jacket sold
harness sold
Thanks guys! will update the thread later
Old 05-19-2008, 11:40 AM   #9
audiko4
audiko4's Avatar
Bump for Shaun and John
http://www.theshopct.com
I want a girl with an accent, and I don't mean a Hyundai.
audiko4 is offline   Reply With Quote
Old 05-19-2008, 12:18 PM   #10
tepid1
tepid1's Avatar
Send a message via AIM to tepid1 Send a message via Yahoo to tepid1
OMG I can't believe it's come to this.....
I am sad right now. All that hard work and time.....
Stewart Race Engines / RLZ ENGINEering / T1 Race Development / Speed Trapp Consulting
Arizona Forced Induction / Hasport / NRG-Tech / Bullhead Gears / Canton Racing Products
tepid1 is offline   Reply With Quote
Old 05-19-2008, 12:26 PM   #11
2 0 3
2 0 3's Avatar
Default Re: Parting out PW/S T/S SFWD Race Car!!! (tepid1)
We are all sad. It is what it is though. If you can't afford it, you can't afford it.
Old 05-19-2008, 01:30 PM   #12
HybridKOOP
HybridKOOP's Avatar
Send a message via AIM to HybridKOOP
Default Re: Parting out PW/S T/S SFWD Race Car!!! (audiko4)
TTT for some insane deals... Jump on this stuff guys, it's basically brand new stuff!
'08 Evolution X
'06 WRX STi
Honda veteran.
HybridKOOP is offline   Reply With Quote
Old 05-19-2008, 01:38 PM   #13
2 0 3
2 0 3's Avatar
Please state your location/Zipcode when pm'ing me. I am getting a million Pm's for the exhaust and i dont know where everyone is located so your XXX.XX shipped offers do me no good, I want to offer this first come first serve but everyone is pm'ing me asking for paypal address and i dont want to end up getting 4 payments for one part.
Just trying to be fair.
Old 05-19-2008, 01:58 PM   #14
rota92
rota92's Avatar
Send a message via AIM to rota92
9.85 @ 145 - SOHC / HR car coming later than sooner
AFAP Racing
RLZ / NRG Tech / T1 Race Development / Bullseye power
Synapse Motorsport / Golden Eagle Mfg. / Innes
Progress Auto / Scott @ Kinsler /AEM/ Your name here
rota92 is offline   Reply With Quote
Old 05-19-2008, 06:30 PM   #15
sikciv666
Senior Member
sikciv666's Avatar
Send a message via AIM to sikciv666
Default Re: Parting out PW/S T/S SFWD Race Car!!! (rota92)
Originally Posted by rota92
x1743982374914759874958014957
sikciv666 is offline   Reply With Quote
Old 05-19-2008, 08:53 PM   #16
2 0 3
2 0 3's Avatar
Default Re: Parting out PW/S T/S SFWD Race Car!!! (sikciv666)
Bump
Old 05-20-2008, 04:47 AM   #17
2 0 3
2 0 3's Avatar
Updated
Old 05-20-2008, 09:06 AM   #18
2 0 3
2 0 3's Avatar
Lunch time going to add some more stuff
Old 05-20-2008, 12:47 PM   #19
2 0 3
2 0 3's Avatar
I will be in Chicago this weekend. Saturday-Monday.
If anyone in that area wants smaller sized parts, let me know ill bring them on the plane with me
Old 05-20-2008, 12:58 PM   #20
alexsracing
alexsracing's Avatar
Send a message via AIM to alexsracing
Default
pm'ed you
2004 Civic EX Daily / 2003 CBR 600RR EFI University certified
1994 civic hatch sfwd t3/t4 10.8@134 unleaded pumpgas
texas valley area. http://www.rgvimports.com
alexsracing is offline   Reply With Quote
Old 05-20-2008, 01:35 PM   #21
2 0 3
2 0 3's Avatar
Default Re: (alexsracing)
replied
Old 05-21-2008, 04:46 AM   #22
2 0 3
2 0 3's Avatar
Default Re: (2 0 3)
morning
Old 05-21-2008, 09:59 AM   #23
2 0 3
2 0 3's Avatar
Default Re: (2 0 3)
Just added Manifold/TB Combo & CF hood with Aerolatch setup !!!
Old 05-21-2008, 11:12 AM   #24
sikciv666
Senior Member
sikciv666's Avatar
buuuuuuuuummmmmmmmppppppppppppp
Old 05-21-2008, 03:17 PM   #25
HondamanXxX
2008 Porsche 911
HondamanXxX's Avatar
Pm'd ya buddy...
HondamanXxX is offline   Reply With Quote
15x9, 4x100, acura, cage, civic, competition, engineering, integra, manifold, radiator, sfwd
