06-23-2008, 12:27 PM
#2
Re: FS: Random Turbo Parts (MyWhiteCivic)
I'm interested in the fuel pump. Where in PA are you located? How much would it be shipped to 21158.
06-23-2008, 12:29 PM
#3
Re: FS: Random Turbo Parts (Red94Sol)
Shipping is $7 to MD. Pickups or meeting up somewhere are always an option also for all items.
Thanks!
Modified by MyWhiteCivic at 4:11 PM 6/23/2008
06-23-2008, 07:14 PM
#4
Page 6 already. Bump it up.
06-24-2008, 08:11 AM
#5
t t t
06-24-2008, 07:46 PM
#6
06-26-2008, 09:30 AM
#7
06-27-2008, 07:22 PM
#8
t t t all PMs replied
06-28-2008, 03:53 PM
#9
Saturday bump
06-28-2008, 08:51 PM
#10
I'm interested in the MAP sensor, is this compatible for a 90 CRX?
I'm currently running Crome and was already told that I would need to get some option on it changed but besides that am I good?
06-28-2008, 08:56 PM
#11
Re: (KevinT707)
I was using the GM MAP sensor with my 95 Civic turbo project using Hondata and it worked great. I see no reason why it wouldn't work for your current setup.
06-29-2008, 08:07 AM
#12
06-29-2008, 05:12 PM
#13
Re: (MyWhiteCivic)
Thanks for the reply, but by upgrading from OEM to 4Bar MAP sensor would I need a re-tune?
06-29-2008, 06:00 PM
#14
Re: (KevinT707)
I'm not familiar with your setup but I didn't retune to use the sensor. I installed it so that I could run 18 lbs of boost then went on over to the dyno to get my software setup.
So to answer your question, I don't think so but I'm not 100%.
07-01-2008, 08:33 PM
#15
Bump New Stuff Added...
*** 2008-07-01 - New Items Added ***
* D16Z6 Civic Valve Cover
* Test Pipe w/ NEW Gaskets
* JDM Optional Audio Center Console (Color: Tan)
07-02-2008, 09:15 PM
#16
t t t
07-04-2008, 07:37 AM
#17
t t t
07-05-2008, 09:44 AM
#18
t t t
07-06-2008, 04:11 PM
#19
07-06-2008, 08:10 PM
#20
Added dimensions of the test pipe:
Approx Dimensions:
Length: 16 5/8"
Inside Diameter: 2 1/8"
07-07-2008, 06:17 PM
#21
what's the best price for the fuel pump shipped to 14226
07-07-2008, 06:21 PM
#22
Re: (tommiboy)
You got PM
07-08-2008, 03:11 AM
#23
t t t
07-08-2008, 08:22 AM
#24
t t t (all PMs replied)
07-09-2008, 09:14 PM
#25
going ttt
| Thread Tools |
Search this Thread |
