Go Back   Honda-Tech > Regional Classifieds > Northeast (Sales)
Old 09-28-2008, 10:11 AM   #1
Crx Jimmy
Crx Jimmy's Avatar
Default OMNI FRONT Aluminum EG/DC contol arms like new!! with extra bushings!!!
For sale , omni front aluminum EG/DC control arms very little use. I went with spherical bearings so I had to use the stock control arms. These retail for $400. make a REASONABLE offer.
website pic
pics of actual ones I have. There New bushings in them and come with extra bushings (in the pics the bushings are 2 slightly different colors) . they are different hardnesses you can put whatever ones you want in them, firm or hard. comes with all.
Unique only to the Omni-Power product line, our light weight front lower control arms (FLCA's) are forged with certified T6-2014 aluminum (100% stronger than 6061-T6). Pure polyurethane bushings are used that wont squeak or crack like other poly bushings that use fillers to cut costs. Each control arm is then hard anodized to eliminate corrosion and maintain a show quality look. Omni-Power uses a solid design for added strength and is the only company to offer an aluminum FLCA for EG and DC model vehicles. These FLCA's are a direct replacement for the front 2 piece design and require no modifications for an easy install. Typical weight savings is approximately 8 pounds depending on the vehicle model. Each nut or bolt attaching the FLCA to the vehicle including the ball joint torques to 38 ft/lbs + or - 2 ft/lbs. If ball joint removal is required to change an axle or other part, use of a pickle fork is needed. Never use a hammer to release the ball joint from the FLCA, as this will damage the FLCA and may cause it to fail. Tested and developed on 1000 HP drag race cars as well as road and auto-x vehicles. This part is suitable for street and track use and is equal in strength to the OEM counter part when installed correctly. You won’t find a higher quality front aluminum control arm anywhere.
link to omni website product page http://www.omnipowerusa.com/product.asp?P_ID=135
Crx Jimmy is offline   Reply With Quote
Old 09-28-2008, 11:13 AM   #2
shaggyeg6si
shaggyeg6si's Avatar
Default
Is the mini jack included?
shaggyeg6si is offline   Reply With Quote
Old 09-28-2008, 11:56 AM   #3
Crx Jimmy
Crx Jimmy's Avatar
Default Re: (shaggyeg6si)
maybe whats the offer
Old 09-28-2008, 12:53 PM   #4
shaggyeg6si
Default
Depends, do you have the matching jack stands?
Old 09-28-2008, 03:12 PM   #5
Rodney
Moderator
Rodney's Avatar
Location: hop,skip, and a jump from the city,, new friggin york, USA
Send a message via AIM to Rodney
wow, awesome arms. i wish i had the $.
Rodney is offline   Reply With Quote
Old 10-02-2008, 04:11 PM   #6
Crx Jimmy
Crx Jimmy's Avatar
Maybe
