Old 02-26-2009, 03:23 AM   #1
Aahj
Aahj's Avatar
Send a message via AIM to Aahj
Default FS: 08 MARRS ITA Champ ITA/H4/PTD 1988 Honda CRX Si
ITA/PTD/H4 1988 Honda CRX Si
Jeff Underwood built
This Car Has Never Suffered from a Mechanical DNF!
Suspension:
Koni 2812 Double Adjustable shocks w/ 89-91 rear LCA's
400F/600R Eibach springs
24 mm rear Suspension Techniques sway bar
Energy Suspension polyurethane bushings all around
Mugen Rear Trailing Arm Bushings
OPM Radius Rod Bearings
Brakes:
All Brand New Honda Components at the beginning of last year with 90-91 parts including:
Front and Rear Calipers
Front and Rear Stainless Steel Brake lines
Master Cylinder
Brake Booster
Proportioning Valve
Hawk DTC-60 brake pads (Jay Andrew at Andrew Racing)
GS 600 Brake Fluid
Custom Brake Ducts for the front
Engine:
Motor Assembled by Kevin Helms at Hondaworks
Head Machined by RLZ Engineering
1 mm Overbore
1" Port Match at Intake and Exhaust Ports
Added .5 Point on Compression Ratio
AEM Short Ram Intake
SMSP Custom Header
Custom Exhaust Piping
Use 100 Octane Fuel
UR Lightened Crank and Alternator Pulleys
Engine 1 Season Old w/ New:
Timing Belt
Water Pump
Bearings/Seals
Pistons
The Works!
Brand New Honda Distributor w/ Ignitor/Coil/Cap/Rotor/Wires/Plugs - All Honda
Chipped ECU Tuned by James Evans at JE Import Performance - 130.8 whp/112.4 ft.-lbs.
Transmission/Driveline:
Brand New Internals 2 Seasons Ago w/ New Honda Parts Including:
Bearings/Seals
Gears
Shift Forks
Synchronizers
Axles (EMPI)
Wheel Bearings (New Last Season)
Heat Treated Hubs (New Last Season)
Extended Wheel Studs (New Last Season)
Skunk 2 Lightened Lug Nuts
14x7 Panasports (2 sets - dirty orange)
This Drivetrain has extremely little drag which adds power to the ground! Less Drivetrain power loss.
Manual Transmission Fluid was Changed After EVERY Race/Track Weekend - Extremely Smooth
4.7 SSR Final Drive
OPM LSD
Int./Safety:
Momo Race Seat w/ Back Brace
Handheld Fire Extinguisher
Window and Side Nets (NASA Legal)
G-Force 6 Point Camlock Belts
Grant GT Steering Wheel w/ Custom Extension
8 Point SCCA/NASA Legal Cage w/ Extra Gussets
Convex Side Mirror
Water Temp/Oil Pressure/A/F Mixture Gauges
ChaseCam Digital Video Recorder w/ Bullet Camera Pointed at Pedals
Race Technology DL-1 Data Acquisition w/ Data Files
I/O Port Camera Mount
Sampson 2 Way Radios w/ Case
Custom Switch Board in Center Console
Pro IT Display (Displays Actual Times from Transponder)
Misc.:
Neat Custom Quick Disconnect Splitter w/ Spare Splitter Planes
Helms Manual
Car Cover
Spares:
One Additional Set of 14x7 Panasports w/ 225/50-14 Hoosier A6's (4 Heat Cycles)
1 New Hoosier 225/50-14 R6
2 Master Cylinders
Brake Booster
Proportioning Valve
Stainless Steel Brake Lines
Front Hubs (Heat Treated) w/ Extended Studs
Left Axle
Distributor Cap
Plug Wires
Plugs
Fuel Filter
Starter
Rear Main Seal
Crank Seal
Cam Seal
Alternator
Lugnuts
Crank Pulley
Front Upper Control Arms/Ball Joints
Front Lower Control Arms
Rear Hub/Bearing Assemblies
Front Knuckles Complete with Bearings/Hubs/Studs/Ball Joints
Distributor
Splitter Plane Material (Alumalite)
ECU
Front Brake Rotors
Comes with a NASA and SCCA Log Book in Good Standing
This car is extremely reliable, but it came at a price. I have the ability, as a mechanic, with a great shop, to completely and thoroughly inspect this car after every race. If I ever noticed ANY thing that could POSSIBLY fail for the next race, I changed the component. For example, I installed brand new Honda front lower ball joints in this car every three weekends. I torqued and retorqued every suspension bolt on that car after every weekend. Even if pads didn't need to be replaced, I made sure that every caliper pin did not bind. Little things like this in car prep go a long way towards reliability.
I think this is one of the top ITA Honda CRX's in the country.
This package, with everything you see above, including my knowledge, can be yours for $12,000. At this time, I won't break up this package. I'm really trying to get rid of this as a whole.
Take care,
AJ
aj@ajnealeyracing.com
443-220-4019
ajnealeyracing.com
Aahj is offline   Reply With Quote
Old 02-26-2009, 03:28 AM   #2
Aahj
Aahj's Avatar
Default Re: FS: 08 MARRS ITA Champ ITA/H4/PTD 1988 Honda CRX Si
Old 02-26-2009, 04:11 AM   #3
Bsixteen_CRX
Bsixteen_CRX's Avatar
bump for a sick car. glws.
1990 CRX Si built B16a Turbo (daily)
1990 CRX Dx D15b (new project)
Bsixteen_CRX is offline   Reply With Quote
Old 02-26-2009, 08:03 AM   #4
Aahj
Aahj's Avatar
Thank you! This car is located in Edgewater, MD
Old 03-01-2009, 09:46 AM   #5
Aahj
Aahj's Avatar
New Pics:
Old 03-01-2009, 02:47 PM   #6
Aahj
Aahj's Avatar
Car has just been aligned and ready to race!
Old 03-02-2009, 11:40 AM   #7
Aahj
Aahj's Avatar
Old 03-03-2009, 03:28 PM   #8
Aahj
Aahj's Avatar
Old 03-11-2009, 09:03 PM   #9
FlatBrokeHatch
FlatBrokeHatch's Avatar
Send a message via AIM to FlatBrokeHatch
Badass...goodluck.
Drugfree and Godfree since 1981.
93' EH3 - built allmotor B18C5(RIP)...on the backup B18C1 for now
FlatBrokeHatch is offline   Reply With Quote
Old 04-02-2009, 06:00 AM   #10
SMSP
SMSP's Avatar
Buy this car.
When one speaks the truth he never has to remember what he said
Defend honesty and never compromise integrity
www.sms-products.com smsptech@cox.net 540-414-6908
SMSP is offline   Reply With Quote
Old 04-02-2009, 07:02 AM   #11
lightweight_
lightweight_'s Avatar
Send a message via AIM to lightweight_
bump for AJ! good luck buddy, let me know if you wanna do a 'farewell' photoshoot for the car before you get rid of it this thing is SICK!!
seanbradfordphotography
- Honda Tuning - Import Tuner - Super Street - S3 Magazine -
lightweight_ is offline   Reply With Quote
Old 04-03-2009, 03:19 PM   #12
lightweight_
up up up
Old 04-03-2009, 03:40 PM   #13
92SikHatchBak
92SikHatchBak's Avatar
NIiiiiiiiiiiiiiiiiiiiCE
92SikHatchBak is offline   Reply With Quote
Old 04-30-2009, 03:54 PM   #14
Aahj
Aahj's Avatar
Thanks guys for the bumps and props.
This package is still available and just lowered the track record at Summit Point Raceway yet again in ITA. It's down to a 1:26.1.
Make an offer!
Thanks for looking,
AJ Nealey
aj at ajnealeyracing dot com
Old 05-01-2009, 01:59 AM   #15
wall-e
1990 Honda CRX
wall-e's Avatar
bump for another crx owner with the same name as me
FIT BIKE CO. com
Trail series 3 (freecoasting and brake less)
wall-e is offline   Reply With Quote
brake, crx, data, ducts, honda, maryland, orange, pin
