Set of 8 Arp extended wheel studs new in package 2 arp 100-7711 45 shipped
Msd 7al2 Ignition boxs, works very well with msd distributer, lots of spark, i have 2 boxes both have about 1/2 a season each, works only with 4cyl. 7224 is the part number, 200 shipped each.
Darton Sleeved B16 with bossed orings, 84mm now, needs .5 mm bore and hone, Aluminum grp rods that need the pins bushed, comes with pistons that are 84mm, mircopolished and knife edged crankshaft, Oil squirter holes plugged, all the seals and bare oil pump (ran a dry sump) come with it, will also include a brand new in the box ARP set of b16 main studs, 1600 obo buyer to pay shipping.
JG engine dynamics b series nitrous cams, USED, made ok power, customer swapped out to a different set that fit his application better. 120 shipped
Set of 310cc accel injectors, dyno time only, needed bigger injectors, 185 shipped.
Look i need this gone. COMPLETE ROLLER, MORE PICS AVAILABLE
MB 1 piece front end, all lexan, mild steel cage, straight axle in the rear, custom front suspension with omni power double adjustable front struts, moroso traction bars, wilwood brakes, weld wheels, like new 26x10 slicks and skinnys, all gauges stay with car, all custom paint, new wheelie bars out back (not pictured) , firewall has been replaced. CAR IS READY TO GO DROP IN YOUR RUNNING ENGINE AND TRANS AND RUN
With dss 5.9 axles and titanuim intermidate bar 6500 (axles fresh from frank)
without axles 5700
THIS CAR IS READY TO GO, IF DOESN'T SELL BY THE TIME I GET THE PARTS I NEED THAN I WILL RACE IT.
Old Proudfoot racing HR car
EK Shell with 02 look, full Chromoly Cage with funny car driver protection just certed to 8.50, custom 2 piece franks fiber glass front end / doors / trunk, prostock wing
NEW window net, NEW 5 point gforce pro belts, HALON system fully charged
Midplate and mounts, engine is moved for better traction
Custom rear suspension with newly rebuilt strange struts
NITRO FRONT SUSPENION AND AXLES STILL 4 LUG, ROB MOORE JUST WENT THROUGH COMPLETE SETUP, NEW SHAFTS AND CV'S AND ENDS, NEW SPOOL, NEW UPGRADED INTERMEDATE BAR
TRANSMISSION COMPLETE new spool, used circuit works final, cryoed gears, and cuff
ALL 4 weld aluma star wheels, NEW 28x10.5x15 mt slicks, NEW goodyear skinnys
custom fuel cell with NEW Aeromotive pro filter
As listed 13,000 well worth it lots of NEW PARTS
With full-race forward facing manifold with twin 46mm tial gates, used garrett 4202, NEW Aluminum piping with used air to water spearco intercooler, NEW holley 90mm tb, used JG 8 injector manifold with rails, and NEW NLR AMS 1000----- 17,000.---------
Full race intake manifold for GSR, Ported by dave at headgames and rewelded by full race
1000 shipped
__________________ http://www.ciscosperformance.com
If you can't afford to do it right the first time, can you afford to do it again?
