06-15-2009, 04:25 PM
#1
Comp Turbo 67mm, 50mm BOV, Full-Race Ramhorn, 1000cc Inj.
Parts for sale- I do not sell used and abused parts. Everything is either new or WORKS!
Garret GT 4294r turbo
Almost new, only 10 dyno passes, SUPER CLEAN TURBO!
T4 twin-scroll flange
1.01 a/r exhaust wheel
3inch v-band dp
$1200 shipped
K20a2 head, 83k, complete with all valve train, vtec solenoid, and cam sensors
$800 shipped
K20a2 alternator
$100 shipped
k20a2 thermostat
$60 shipped
K20a2 knock sensor
$45 shipped
EP3 Idler pulley, belt, and bolts... Installed but never ran
$75 shipped
K20a2 belt tensioner
$40 shipped
Secondary o2 sensor off k20a2
$75 shipped
k20a2 crank pulley
$40 shipped
K20a2 waterneck for head
$25 shipped
k20a2 starter
$75 shipped
K20a2 throttle body with sensors
$200 shipped
K20a2 intermediate shaft
$150 shipped
k20a2 02-04 engine harness with charge harness and fuse box, perfect condition
$325 shipped
Shift linkage and box
$250 shipped
OBX 50mm silver BOV brand new never installed
$140 shipped
OEM k20a2 cat
$50 shipped
stock k20a2 exhaust manifold
$25 shipped
PRB intake manifold
$60 shipped
Stock k20a2 injectors
$60 shipped
NEW ATI Damper for Kseries still in box, never even mounted
Part# 918478, Race version, no belts included
$400 shipped
K20a2 head. Installed Inline Pro springs and retainers. Comes with valve cover. Still on engine. Will pull off when paypal is received
$1100 shipped
Bosch 1000cc injectors
Tuned a car then drove for 80 miles, so damn near brand new
Not enough for the power I am going for
Willing to trade for 1600cc injectors or enough cash to get me some 1600cc.
Fiberglass roof replacement for 92-95 civic hatchback.
Not using this, going with carbon fiber. It is a replacement roof, you have to cut your stock roof off and replace it with this one, it CAN NOT be used as just a roof cap.
$400 shipped
Type S shifter box
$75 shipped
PRB ecu out of 02-04 type S
$300 shipped
02-04 Type S wiring harness, needs a new plug and don't know what sensor plug was cut off
$150 shipped
K20a2 intake sensor
$20 shipped
K20a2 02-04 slave cylinder
$40 shipped
Stock Type S axles, 40k and perfect condition
$150 shipped
Stock k20a2 water pump with 40k
$40 shipped
k20a2 timing chain
$40 shipped
k20a2 timing chain guides
$30 shipped
k20a2 oil pump chain,gear,guide/tensioner
$100 shipped
k20a2 stock head bolts
$19.99 shipped
k20a2 oil pan standard or with -10an oil drain fitting
$100 shipped or $135 shipped
k20a2 stock pistons and rods with 80k
$75.25 shipped
k20a2 stock crank
$199.99 shipped
k20a2 timing chain cover
$49.69 shipped
k20a2 windage tray
$30 shipped
K20a2 water port on front of head
$25 shipped
K20a2 thermostat and pipe
$74.99 shipped
K20a2 coil packs
$59 shipped
k20a2 engine mount
$20 shipped
k20a2 injector cover
$40 shipped
k20a2 stock fuel rail
$25 shipped
30x12x3" Intercooler with 3" outlets
Core is 24x12x3"
Bar and plate, has spot where a wastegate was rubbing but it doesn't leak.
$125 shipped
B-series Full Race ramhorn
T4 and coated with the hot temp coating
bung for EGT welded on (does not come with EGT probe in the picture)
$700 shipped or $850 shipped with wastegate and dumptube
B-series Skunk 2 adjustable cam gears (needs one screw in each one. I had to borrow it for another project, LOL)
$150 shipped
B-series obd2 alternator
$60 shipped
LS AC compressor
$60 shipped
3" AEM dryflow filter
$60 shipped
Autometer Tach
$50 shipped
 [/quote]
NEW Animal House Racing vacuum block
$30 shipped
Rear cargo cover for 94-00 integra
$75 shipped
Wiper motor assembly for 92-95 civic
$75 shipped
92-95 civic eg hatch headlights
$100 shipped
Integra LS cluster
$35 shipped
92-95 civic amber corners... EG hatch
$25 shipped
92-95 civic cluster
$20 shipped
Integra B-series VTEC head carbon fiber spark plug cover
$50 shipped
Hit me up and let me know what you want!
Team Atomik Speed in Dallas/Fort Worth coming strong in 2010
Brice @ Alamo Autosports, Stan @ FastTurbo, Erik @ Bullhead gears, Mike @ K-tuned
K24/20 Turbo Hatch Build http://honda-tech.com/showthread.php?t=2738027
06-15-2009, 04:26 PM
#2
Re: Comp Turbo 67mm, 50mm BOV, Full-Race Ramhorn, 1000cc Inj.
GOOD DEALS!
06-15-2009, 06:14 PM
#3
how much for injectors?
06-15-2009, 06:20 PM
#4
CT turbos are very nice turbos, not known very well in the honda worls but are known very well in the supra community.
also these are great prices, bump for you !
SC300 GTE powered 10.6@132
Top Dead Center Performance( www.tdcperformance.net)
Mobile Alabama, 251-661-6067
06-15-2009, 06:29 PM
#5
I loved this same turbo on my integra. Had 2.0 gsr with ramhorn and made 466 on 17psi.
Only difference was the turbo was non divided.
Yeah, I know what you mean, My buddy that is into Supra's and Lexus's got it for me...
06-15-2009, 09:11 PM
#6
06-16-2009, 12:10 PM
#7
06-16-2009, 02:38 PM
#8
pm sent
06-16-2009, 07:41 PM
#9
back to you
06-17-2009, 06:32 PM
#10
LOTS OF GOOD STUFF!!!
06-17-2009, 07:21 PM
#11
can i get pics of the full race t4 manifold
<321
*Sheepey Built/Vazquez Speed Shop/BMC Race/CNS Polish Works*
06-17-2009, 08:50 PM
#12
Yes sir, I will get some tomorrow
06-18-2009, 05:05 PM
#13
06-20-2009, 12:37 AM
#14
traded CT turbo for GT4294r... its on its way here... will be for sale once i get it...
on another not3... pics of IC and full race mani added
06-20-2009, 07:21 PM
#15
added pics
06-22-2009, 08:13 PM
#16
PM sent
07-01-2009, 01:12 PM
#17
07-03-2009, 12:57 PM
#18
pics of fiberglass race roof.
how much does it weigh?
50mm, 67mm, bovs, chain, comp, compturbo, full, horn, k20a2, manifold, race, ram, series, timing, turbo  |
| Thread Tools |
Search this Thread |
