Clean out garage (cheap or free parts) 95 civic, DA integra, +more LowBallers Welcome
Its time to clean out my garage. Please bump thread and PM me for quicker response
I prefer pickup on most items. Name your offer, low ball the offer so you can have it. If you want me to ship it you must pay by paypal and pay for shipping. Either UPS ground, USPS Regular flat rate box @ $10 or USPS large flat rate box $15. All will be shipped with tracking
Anyhow, these are parts I have accumulated for nearly 10 years and if I dont know what it goes to it goes to one of the past cars I have owned so your guess is as good as mine if its not labeled:
1995 Honda Civic del sol si
1995 Honda civic ex
1990 - 1993 Acura integra (i have owned all of these years over time)
1995 Honda accord ex wagon
1990 honda crx dx
1991 honda crx si
If I kept the part it means it wasnt the problem or I have stated whats wrong with it next to it. Example: I am selling the heater core valve for the accord below, I replaced it thinking that was the reason why my valve was not opening all the way up and it turned out being the cable.
Please reply in this thread for any questions, keep it bumped up
1995 Del Sol Si 5 speed tranny 3rd and 4th gear syncro grind model A20/S20
1999 Civic automatic drivers side axle, boot torn otherwise good
1995 civic rear mount
1992 Acura upper stock exaust manifold, no leaks
1991 Acura radio bezzle with ashetray and cig lighter plug
1995 civic driver side door latches, one with power locks, one without
1995 del sol center vent replacement item with generic boost and volt gauge
1991 Acura integra drivers side fender well plastic
1993 Acura integra passenger side under rain gaurd (automatic if that matters)
1991 Acura integra a/c compressor (not seized)
1991 integra oem cat heat sheild
1991 integra hood latch and the thing that holds it
1991 integra same as above without the latch
1991 integra condensor, bent slightly from wreck but no leaks.
unknown starter
2 different Unknown motor mount drivers side brackets
1995 honda accord ex master cylinder
1991 integra wheel hub and assembly with the lower arm
1995 honda civic washer res with motor
unknown altenator
unknown starter
1995 honda civic door outter handles painted silver, one is bad
1995 civic ex timing belt covers
1995 integra GSR drivers side motor mount
1995 civic under hood cruise control box
1995 AC parts (in the box) mount, dryer, 2 uncut lines, pulley, rubber mount
unknown lower timing cover (think its from d16z6)
1991 integra oem clutch and pressure plate 75% life left
2 sets of power steering pumps and res from 1995 civic ex
Close ups and what not
1995 civic power steering pump
1995 civic power steering pump and res
Unknown ps res
Closeup of model # and serial # of tranny
Drivers side integra quarter panel stripping (someone spray painted it black, i think it was originally black as well), GSR motor mount, civic timing belt upper covers (dirty looking one sold in previous local thread)
1992 integra oem upper manifold
Civic outter door handles w/ key cylinders, one on the left is broken
1990 crx DX under hood fuse panel (i think i remember it threw an ELD code)
1995 civic drivers side door latches, one with power locks, one without
1995 used but works fine heater core valve
broken TPS's free that you can solder on if your broke and need a TPS (just pay shipping, should be $3 for USPS first class tracked)
Unknown altenator
same Unknown altenator as above, just showing plug
unknown starter
1991 integra condensor, bent from wreck as mentioned above but still holds pressure.
1991 integra a/c compressor, not seized
1991 integra drivers fender white, not bent
