Old 10-05-2009, 02:02 PM   #1
Quad-Damage
Quad-Damage's Avatar
Send a message via AIM to Quad-Damage
Default 2000 Honda Civic DX 4 Door. Turbo D16Y8 Honda Tunning July 06 Car *Low Miles*
I'm selling my Honda Civic Turbo 4 Door. It's my 1st car. I am a none smoker. The cars motor can handle up to 400whp or more on race gas. The car has never seen race gas or over 15 psi. The car has run mid 12's on bfg drags. The car can do 11's on slicks. It's a very fun DD or street/race setup. It's really just needs some paint to set it off and make it your own. No test drives without cash deposit. I can help the owner smog the car, but it might co$t extra
* Name: Alex
* Means of Contact: pm or email TurboCivicbayarea@yahoo.com
* Vehicle Year/Make/Model: 2000 Honda Civic DX
* Color: Smoked Gray Gunmetal (Jams and Bay are Black) Inside is Green
* Factory Options: Heat, PS just needs belt, Power door locks. No Back seats
* Mileage: 32,XXX miles
* D16Y8 Motor has under 4,000 on freshly built motor
* Title: Clean Title
* Price: 6,900 obo
Only TRADES I would take would be S2000 + cash on my side. I'm done with race cars. No Civics or Tegs.
Motor
Full D16Y8 Block (REDZONE BUILT)
Darton Sleaves 75mm .20 over 1.6 LITER
Bored, Honed, Decked
Blanced and Blueprinted Block
Wesico Pistons -w- rings, with the coated skirts
Eagle 900HP H Beams Connecting Rods
Crank balanced, polished
OEM HONDA! Bearings
New Oil Pump (Honda) Shimmed for high flow
New Water Pump (Honda)
New Alternator Honda)
NEW OEM HONDA Heat shield Gasket Intake)
Feels Pro Headgasket + Gasket Kit
Head
Full D16y8 Head (CLEANED)
9.0.1 comp overall
Redzone P&P 3 angel job both sides, intake and exhaust (SUPER NICE)
D16y8 ARP Head Studs Torqued to Spec
ZEX Honda D16Y8 - Stage 1 Street/Strip Performance Cam
Ferrea Racing 6000 Series Competition Valves .5 Oversized (YES 6000 SERIES)
Ferrea Racing valve springs
Ferrea Racing Components Titanium Retainers
Tyranny
Rebuild RedZone D16z6 5 Speed Iron Shift Forks (NEW OEM HONDA)
RedZone Stage 3 Clutch
ACT XACT Street Lite Flywheel 11 pound
OBX LSD Beveled so i can take the axles out
ALL NEW OEM HONDA BEARING AND WASHERS Installed and Torqued to Spec
Gator Stage 2/3 Axles 400whp
ARP Extended studs, for mounting my monster 24.5 9 13's slicks
Motor Bolt On's (Other Parts Inside of the Motor Bay)
MSD SCI 10,000RPM
MSD Blaster 2 Coil
2000 Honda Civic MSD Cap and Coil with New Inginitor Setup for MSD
Hondata 3 Bar Sensor (CUSTOM MOUNTED) on Firewall * Car is Ruining On 3 Bar 1000 Idle PERFECT*
2000 D16y8 Engine Harness, Car is All Wired for VTEC (WIRED TUCKED)
2000 Honda Civic D16y8 CUSTOM Sheet METAL MADE POWER MANIFOLD (ported by Redzone) *JET Coated Manifold*
2001 Integra Type R Throttle Body 64mm
AEM Tru-Time Adjustable Cam Gears (Silver) COVERED
AEM Tru-Power Pulleys (Red)
AEM High Performance Fuel Filter (Red)
AEM Fuel Rail (Red)
AEM Fuel Pressure Regulator (Red)
Walbro 255LPH Fuel Pump
RC 750 sats injectors with OBD 1 Clips
Fluidyne Radiator 1/2 Size for a B Series, Custom Mounted on my D (POLISHED)
Greedy Oil Cooler Kit
B&M Oil Cooling kit for small Trucks (Keep the Oil very cool)
Greedy Oil Cooler Lines And Adapters 100 PSI UPGRADED LINES (THESE LINES cost me alot of BANK)
Greedy Water Temp Kit
Custom QuadWarez Ground Hyper Wires
Nology Hot Wire Spark Plug Wires
NGk Stage 3 Colder Plugs Gaped .28
Turbo Setup
Black Hallman Manual Boost Controller (0 to 25 PSI) Not a home made nob (Set at 14 psi)
Spoolin Performace Tubular D Series Manifold *ONLY ONE EVER MADE* For a D Series *JET Coated Manifold*
Precision T3/T4 Street & High Performance SC-3427E .57 Trin *JET Coated Housing*
Tail Wastegate 10 PSI 38mm
*JET Coated* Tail BOV 50mm
Spoolin Performance 2.5 inch to 3 inch DMH E-cutout **JET Coated** With metal motor protection custom fitted
Spoolin Performance Oil Feed Lines
Spoolin Performance Oil Return Lines
Spoolin Performance 2.5 inch Charge Pipes POLISHED aluminum
Spoolin Performance Dump tube *JET Coated*
JRC 8 Inch Inter cooler *JET Coated*
Exterior & Inside
2000 Honda Civic Black Si Dash,(Black in color) and FULL Interior (COMPLETE SWAP WITH THE CARS LEGIT VIN) + WITH BLUED TAG! by CHP ALL LEGIT!
Custom Fitted, with JDM ARM Rest and custom gauges all black, SUPER SICK INSIDE! + Cutout cockpit button for cutout
2000 Honda Civic Si Climate Control Unit (FULL SI INSIDE, Moon, Sun, Power Roof ALL)
Omni Power Custom detachable hub Quick Release
Momo Steering Wheel Hub
Momo Steering Wheel with Bride Logo
1 Black F1 Spec Seat with Custom Civic Rails.
1 Bride ERGO II Black FA [E11ATS] Seats 2 (YES BOTH) in BLACK with Custom Bride Rails
Both seats are faded from the sun, one seat is broke, will get 3 seats with the car.
Civic 2 Pod Gauge Holder On Cluster
Defi D-Gauges 52mm 0-35 psi Boost Gauge
Nordskog performance LED Digital Fuel Pressure 0 - 100 psi-RED Display
Fuel Pressure Sending Unit Kit
Summit Digital Gauges 2 1/16 in. diameter, black face, red LED display, voltmeter, water temperature, and oil pressure gauge, digital gauge panel kit
Summit Racing Senders For Voltmeter,water temp, and oil pressure
FD Extreme Bulb 100/130W Platinum White
Black JDM Headlights
Si Gauge Cluster 30k MILES!
OEM 00 Si Shift Boot
2001 GSR OEM Shifter
Skunk 2 Shift Nob
Power Door Locks All 4 Doors
Stock OEM Honda Radio
MB Quarts DKC 169 6.5 in Rear 2x
MB Quarts DKD 113 5.25 in Front 2x
YES I RUN 2 Alarms (MORE INFO WHEN BOUGHT $2000 + Setup Similar to Lowjack but much better different kinda top secret) Only new owner will know
NO Spoiler, never installed one
Repainted in 2004 Custom GUNMETAL COLOR, SMOKED GRAY starting to oxidize
99-00 Carbon Creation Carbon Fiber Front Grill oxidize
Carbon Fiber Hood rolled oxidize
Carbon Fiber Mugen Front Lip few dings not oxidize
Suspension/Brakes
Brembo Front Cross Drilled Rotor System
PBR Ultimate Ceramic brake pads *GREAT PADS*
99-00 Civic JDM Civic Type R E brake cables
01 Acura Integra GSR Rear Disk Brakes
01 Acura Integra GSR Rear Disk AEM Brake Pads (Pads have 5000 miles on em)
Omni Power Full Coil overs with upgraded collers for 700whp
Omni Power Front Camber Kit
Omni Power Rear adjustable camber links, 2 inches in back and 2.2 in front (NOT WASHERS)
Suspension Techniques Speedtech Sway Bar System
Back Strut Polished Bar
Custom Quadwarez High Temp Gunmetal Painted Calipers EX
Custom Quadwarez High Temp Gunmetal Painted Calipers GSR
Zenki Red Extended Lug Nuts 16 4 x 4
ARP Extended Studs for Mounting Slicks
Gator Stage 2/3 Axles 400whp +
Full Race Gold Polished Traction Bar
Polished Hasport Race Mounts 70mm (RACING MOUNTS) Drive Side, Tranny, Rear Engine Mount, Shifter Mounts
Buddy Club P II New Tires 225 15 inch Drag Radials G-force's on the Fronts %95 + left may be 400 miles on them
and Dunlop Durizoes in the Rear 205 %98 left may be 400 miles on them
Wheels
Buddy Club P II New Tires 225 15 inch Drag Radails G-force's on the Fronts %95 + left maby 400 miles on them
and Dunlop Durizoes in the Rear 205 %98 left maby 400 miles on them
Tunning
6 hours of Dyno Time
3 hours of Street Tuning
p28 Chiped with CROME PRO STREET TUNED AND DYNO TUNED BY JEARMY and BRANDON from Redzone Performance
P28 Redzone Chiped and Tuned Crome PRO
321whp and 228tq @ 14 psi. RUNS ON 91 PUMP GAS!
H Beams and the Sleaved Block, You can see the noachs that were put in
321WHP WITH A TUrbo Filter
327WHP with 4 inch V stack on Turbo
13 psi
12 psi old base map tune
12.7 @ 115 mph with a 2.0 6 0 foot ouch! can do low 12's on PUMP! 11's on race gas easy.
E Cutout
FULL RACE!
2000 Honda Civic Turbo Fully Built For Sale. Low Miles. Clean Title!
http://www.hondamarketplace.com/show....php?t=2658108
Quad-Damage is offline   Reply With Quote
Old 10-05-2009, 02:04 PM   #2
Quad-Damage
Default Re: 2000 Honda Civic DX 4 Door. Turbo D16Y8 Honda Tunning July 06 Car *Low Miles*
I wanted to update my add Better?
Old 10-05-2009, 03:28 PM   #3
Quad-Damage
I like it
Old 10-05-2009, 05:26 PM   #4
Quad-Damage
Old 10-05-2009, 08:04 PM   #5
srt4mike
2005 Dodge SRT-4
srt4mike's Avatar
srt4mike is offline   Reply With Quote
Old 10-06-2009, 12:26 AM   #6
Quad-Damage
st4mike ftw!
Old 10-06-2009, 01:20 AM   #7
IT'S ME DAVID
JERRYBUILT NUFF SAID'
IT'S ME DAVID's Avatar
ttt
JERRYBUILT Nuff Said'
00 TAFETTA WHITE CTR REP 600 WHP EK
http://www.youtube.com/aDJMproduction
IT'S ME DAVID is offline   Reply With Quote
Old 10-06-2009, 09:06 AM   #8
Quad-Damage
Thanks yo
Old 10-06-2009, 10:59 AM   #9
Quad-Damage
bump!
Old 10-06-2009, 11:11 AM   #10
patrickd_21
patrickd_21's Avatar
gotta keep the D's ontop!
patrickd_21 is offline   Reply With Quote
Old 10-06-2009, 04:24 PM   #11
Quad-Damage
Turbo D16 FTW
Old 10-06-2009, 04:27 PM   #12
ALLxMOTOR EG
Vietnamese!
ALLxMOTOR EG's Avatar
Bump for viewing.
ALLxMOTOR EG is offline   Reply With Quote
Old 10-06-2009, 04:28 PM   #13
Quad-Damage
Thanks
Old 10-06-2009, 05:32 PM   #14
sde780
sde780's Avatar
Send a message via AIM to sde780
Insane car, legit price
93 Del Sol - Y7 swap
98 Civic - bone stock
sde780 is offline   Reply With Quote
Old 10-06-2009, 07:13 PM   #15
Quad-Damage
Thats what I'm saying. I think the asking price is more then fair, paint is cheap
Old 10-06-2009, 08:34 PM   #16
DougiePants
DougiePants's Avatar
bump for viewing
Special Thanks : HyTech, ACT, Quaife, HARDTOPGUY, Puddymod, GTMotoring, Enkei, & ARC
DougiePants is offline   Reply With Quote
Old 10-07-2009, 12:10 AM   #17
Quad-Damage
UPPP!
Old 10-07-2009, 05:14 AM   #18
patrickd_21
nothing better then destroying a V8 with a 1.6L 4cyl
Old 10-07-2009, 09:48 AM   #19
Quad-Damage
Running 12's on street tires
Old 10-07-2009, 11:10 AM   #20
Quad-Damage
bump for boost
Old 10-07-2009, 11:22 AM   #21
Eklsv-t
Eklsv-t's Avatar
someon cash this guy out so he cash out my s2k
96 Honda Civic Cx HB- LS Vtec-T/DD- Totalled 11/12/08
Eklsv-t is offline   Reply With Quote
Old 10-07-2009, 11:29 AM   #22
Quad-Damage
^^ thats the plan
Old 10-07-2009, 01:21 PM   #23
patrickd_21
keeping the d's ontop
Old 10-07-2009, 02:55 PM   #24
Quad-Damage
Turbo D's!
Old 10-07-2009, 04:34 PM   #25
Quad-Damage
BUMPIN!
00, 2000, 4door, civic, d16y8, door, engine, harness, head, honda, psi, rail, sale, swap, type
