Thank you for your interest in products from AssaulTECH. We provide a large line of name brand, in stock performance parts, all at a recession-proof price. We are honest people giving you honest information about the parts we sell. We are available by email or phone during business hours and try our best to answer every single call. We can usually be reached after hours , just call or email! Contact us to find out how we can help you enhance your car.
You, the customer is our #1 priority. Without you, we wouldn't exist.
Don't forget! We beat all competitor's prices, just contact us if you find it cheaper!
Phone : 205-588-0960 x 1
AIM : AssaulTECH Jay
Email : jay@assaultech.com
We are the lowest price on the net, GUARANTEED! If you find it cheaper anywhere else, we will beat their price!
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
FEATURES
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
GT Pro Coilovers
Product Description
Ksport GT Pro Damper System provides the ultimate in suspension technology featuring its inverted monotube design, 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. With the gas/oil chamber farther away from the knuckle and braking system reducing heat transfer This design also reduces under-sprung weight, which improves handling and responsiveness.
FEATURES
Inverted steel shock absorber for durability
Lower center of gravity and higher chassis rigidity
Designed to reduce friction for cooler shock oil temperature
Inverted design like vehicles in WRC and all JGTC cars
Ksport GT Lowering Springs have been designed to give your car superior handling with an aggressive race look. Most other brands use a linear rate, but Ksport utilizes a progressive rate for several reasons. A progressive rate allows a plush comfortable ride under normal travel, but since the rate shifts higher during compression, it stops “body roll” during heavy braking, hard acceleration, or fast cornering. By lowering the center of gravity from OE height you dramatically improve performance and handling characteristics.
FEATURES
Progressive rate design
High tensile chrome silicone wire
Cold wound for strength
Shot peened for increased stress relief
Aggressive drop while retaining superb handling characteristics
205-588-0960
THREE EASY WAYS TO ORDER
1. Click the product link above and add it to your cart, then use promo code MODIFIED and enjoy FREE SHIPPING and Forum Pricing (Please note some prices are as low as they go before promo code) 2. Call us! (205)588-0960 x 1 3. See total by adding it to your cart and send PayPal payment to paypal@assaultech.com
We accept Visa, Mastercard, Discover, Amex, PayPal, Wire Transfers and Checks.
We look forward to serving you!
